Algorithms for Wavefront Reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Knowing the solution to Helmholtz equation in a narrow band, with a width of order wave length around a scatterer, we investigate the possibility to construct the wave fronts predicted by the asymptotic methods Geometrical Optics (GO) and Geometrical Theory of Diffraction (GTD). More specifically we show how to build a polynomial approximation of the asymptotic solution on a circle around the scatterer and hence, in a second step, be able to propagate this solution by wavefront construction methods or standard ray-tracing.
Autre [cs.OH]
RR-5696.pdf (425.15 Ko) Télécharger le fichier
inria-00070319 , version 1 (19-05-2006)
  • HAL Id : inria-00070319 , version 1
Stefan Hagdahl. Algorithms for Wavefront Reconstruction. [Research Report] RR-5696, INRIA. 2005, pp.28. ⟨inria-00070319⟩
40 Consultations
86 Téléchargements
