Equilibria of a Class of Transport Equations Arising in Congestion Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
This paper studies a class of transport equations arising from stochastic models in congestion control. This class contains two cases of loss point process models: the rate-independent Poisson case where the packet loss rate is independent of the throughput of the flow and the rate-dependent case where the point process of losses has an intensity which is a function of the instantaneous rate. This class of equations covers both the case of persistent and of non-persistent flows. We give a direct proof of the fact that there is a unique density solving the associated differential equation and we provide a closed form expression for this density and for its mean value.
RR-5653.pdf (246.7 Ko) Télécharger le fichier
inria-00070357 , version 1 (19-05-2006)
  • HAL Id : inria-00070357 , version 1
François Baccelli, Ki Baek Kim, David R. Mcdonald. Equilibria of a Class of Transport Equations Arising in Congestion Control. [Research Report] RR-5653, INRIA. 2005, pp.19. ⟨inria-00070357⟩
137 Consultations
161 Téléchargements
