Electrocap: A Shape Inverse Model for an Electro-Capillarity Process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
Electrocap is a freeware modelling an electrified droplet at equilibrium and wetting a solid surface. The model consists to seek the drop shape by minimizing its total energy (capillary, electrostatic and gravitational). To this end, the model is based on the classical shape optimal design method. In this paper, we derive the equations and the shape gradient; we detail the shape optimization algorithm implemented and present some numerical results. The code is based on the public mesh generator Bamg and the public C++ finite element library Rheolef.
Autre [cs.OH]
RR-5617.pdf (346.52 Ko) Télécharger le fichier
inria-00070391 , version 1 (19-05-2006)
  • HAL Id : inria-00070391 , version 1
Jerome Monnier, Patrick Chow-Wing-Bom. Electrocap: A Shape Inverse Model for an Electro-Capillarity Process. RR-5617, INRIA. 2005, pp.30. ⟨inria-00070391⟩
118 Consultations
283 Téléchargements
