Automatic Middleware Deployment Planning on Clusters - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2005
The use of many distributed, heterogeneous resources as a large collective resource offers great potential and has become an increasingly popular idea. A key issue for these Grid platforms is middleware scalability and how middleware services can best be mapped to the resource platform structure. Optimizing deployment is a difficult problem with no existing, general solutions. In this paper we address a simpler sub-problem: how to carry out an adapted deployment on a cluster with hundreds of nodes? Efficient use of clusters alone or as part of the Grid is an important issue. We present a deployment model that predicts the maximum throughput of each element of a deployment. Our deployment construction algorithm uses this model to automatically create a mapping of middleware elements onto resources with the goal of maximizing throughput. We apply our approach to automatically deploy a distributed Problem Solving Environment (PSE) on a homogeneous cluster environment. We present experiments comparing the automatically-generated deployment against a number of other reasonable deployments.
Domains
Other [cs.OH]
RR-5573.pdf (245.77 Ko) Télécharger le fichier
Dates and versions
inria-00070433 , version 1 (19-05-2006)
Identifiers
  • HAL Id : inria-00070433 , version 1
Cite
Eddy Caron, Pushpinder Kaur Chouhan, Holly Dail. Automatic Middleware Deployment Planning on Clusters. [Research Report] RR-5573, INRIA. 2005. ⟨inria-00070433⟩
280 View
194 Download
Share
Gmail Mastodon Facebook X LinkedIn More
