Estimation of the Weibull tail-coefficient with linear combination of upper order statistics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
We present a new family of estimators of the Weibull tail-coefficient. The Weibull tail-coefficient is defined as the regular variation coefficient of the inverse failure rate function. Our estimators are based on a linear combination of log-spacings of the upper order statistics. Their asymptotic normality is established and illustrated for two particular cases of estimators in this family. Their finite sample performances are presented on a simulation study.
girard.pdf (180.82 Ko) Télécharger le fichier
inria-00070435 , version 1 (28-09-2005)
inria-00070435 , version 2 (19-05-2006)
  • HAL Id : inria-00070435 , version 1
Laurent Gardes, Stéphane Girard. Estimation of the Weibull tail-coefficient with linear combination of upper order statistics. [Research Report] RR INRIA 5571, INRIA. 2005. ⟨inria-00070435v1⟩
239 Consultations
366 Téléchargements
