Modeling and Numerical Simulation of Space Charge Dominated Beams in the Paraxial Approximation - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2005
This work is devoted to the modeling of space charge dominated particle beams in the paraxial approximation with several types of external focusing fields (uniform, periodic and alternating gradient). A solid mathematical background for numerical beam simulation is established. The Kapchinsky-Vladimirsky distribution which can be matched exactly or numerically to the focusing channel is first studied. Then the matched KV beam is used to approximately match arbitrary beams. Moreover Water-Bag and Maxwell Boltzmann beams are studied to give analytical solution for code validation. Finally, numerical simulations are presented in different configurations.
RR-5547.pdf (622.92 Ko) Télécharger le fichier
Dates and versions
inria-00070460 , version 1 (19-05-2006)
Identifiers
  • HAL Id : inria-00070460 , version 1
Cite
Francis Filbet, Eric Sonnendrücker. Modeling and Numerical Simulation of Space Charge Dominated Beams in the Paraxial Approximation. [Research Report] RR-5547, INRIA. 2005, pp.31. ⟨inria-00070460⟩
173 View
318 Download
Share
