The Spherical Constraint in Boolean Quadratic Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Global Optimization Année : 2007
We propose a new approach to bound Boolean quadratic optimization problems. The idea is to re-express Boolean constraints as one ''spherical'' constraint. Dualizing this constraint then amounts to a semidefinite least-squares problem which can be efficiently solved. Studying this dualization also provides an alternative interpretation of the relaxation and reveals a new class of non-convex problems with no duality gap.
Autre [cs.OH]
07-malick.pdf (205.54 Ko) Télécharger le fichier
inria-00070518 , version 1 (19-05-2006)
inria-00070518 , version 2 (25-03-2013)
Jérôme Malick. The Spherical Constraint in Boolean Quadratic Programs. Journal of Global Optimization, 2007, 39 (4), pp.609-622. ⟨10.1007/s10898-007-9161-1⟩. ⟨inria-00070518v2⟩
192 Consultations
775 Téléchargements
