A constraint-based algorithm for analysing memory usage on Java cards - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2004
We address in this paper the problem of statically determining whether a JavaCard applet may produce a memory overflow because of the dynamic instantiation of classes inside cycles. We provide a constraint-based algorithm which determines potential loops and (mutually) recursive methods. The algorithm operates on the byte-code of an applet. It is written as a set of rules -one for each byte-code instruction- which allows a compositional reasoning and it comprises both inter- and intra-procedural analysis. We aimed at an algorithm suitable to be fed into the proof assistant Coq in order to extract a certified memory usage analyser. We prove termination of the algorithm as well as its soundness and completeness with respect to an abstraction of the operational semantics of the language.
Domains
Other [cs.OH]
RR-5440.pdf (386.45 Ko) Télécharger le fichier
Dates and versions
inria-00070567 , version 1 (19-05-2006)
Identifiers
  • HAL Id : inria-00070567 , version 1
Cite
Gerardo Schneider. A constraint-based algorithm for analysing memory usage on Java cards. [Research Report] RR-5440, INRIA. 2004, pp.26. ⟨inria-00070567⟩
79 View
91 Download
Share
Gmail Mastodon Facebook X LinkedIn More
