s'authentifier
version française rss feed
inria-00070610, version 1
Delaunay Triangulation Based Surface Reconstruction: Ideas and Algorithms
Frederic Cazals () 1, Joachim Giesen
N° RR-5393 (2004)
Résumé : Given a finite sampling $P\subset\mathbbR^d$ of an unknown surface $S$, surface reconstruction is concerned with the calculation of a model of $S$ from $P$. The model can be represented as a smooth or a triangulated surface, and is expected to match $S$ from a topological and geometric standpoints. In this survey, we focus on the recent developments of Delaunay based surface reconstruction methods, which were the first methods (and in a sense still the only ones) for which one can precisely state properties of the reconstructed surface. We outline the foundations of these methods from a geometric and algorithmic standpoints. In particular, a careful presentation of the hypothesis used by these algorithms sheds light on the intrinsic difficulties of the surface reconstruction problem faced by any method, Delaunay based or not.
  • Domaine : Informatique/Autre
  • Mots-clés : REVERSE ENGINEERING / SHAPE APPROXIMATION / SURFACE RECONSTRUCTION / DELAUNAY / VORONOÏ
  • Référence interne : RR-5393
  • inria-00070610, version 1
  • oai:hal.inria.fr:inria-00070610
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 21:00:40
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:24
tous les articles de la base du CCSd...
