Delaunay Triangulation Based Surface Reconstruction: Ideas and Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Frédéric Cazals
Joachim Giesen
  • Fonction : Auteur
Given a finite sampling $P\subset\mathbbR^d$ of an unknown surface $S$, surface reconstruction is concerned with the calculation of a model of $S$ from $P$. The model can be represented as a smooth or a triangulated surface, and is expected to match $S$ from a topological and geometric standpoints. In this survey, we focus on the recent developments of Delaunay based surface reconstruction methods, which were the first methods (and in a sense still the only ones) for which one can precisely state properties of the reconstructed surface. We outline the foundations of these methods from a geometric and algorithmic standpoints. In particular, a careful presentation of the hypothesis used by these algorithms sheds light on the intrinsic difficulties of the surface reconstruction problem faced by any method, Delaunay based or not.
Autre [cs.OH]
RR-5393.pdf (457.19 Ko) Télécharger le fichier
inria-00070610 , version 1 (19-05-2006)
  • HAL Id : inria-00070610 , version 1
Frédéric Cazals, Joachim Giesen. Delaunay Triangulation Based Surface Reconstruction: Ideas and Algorithms. RR-5393, INRIA. 2004, pp.42. ⟨inria-00070610⟩
434 Consultations
1926 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
