Global and local parameter estimation of a model of the electrical activity of the heart - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Hervé Delingette
Maxime Sermesant
Owen Faris
  • Fonction : Auteur
Elliot R. Mcveigh
  • Fonction : Auteur
Nicholas Ayache
In this article we study the problem of estimating the parameters of an electrical model of the heart from a temporal recording of extracellular potentials. The chosen model is the reaction-diffusion model on the action potential proposed by Aliev and Panfilov. The strategy consists in building an error criterion based upon a comparison of depolarization fronts between the model and the measures. This error criterion is minimized by a global and then local adjustment of the model parameters. The feasibility of the approach is demonstrated on simulated and real measures on a canine heart.
RR-5269.pdf (1.4 Mo) Télécharger le fichier
inria-00070729 , version 1 (19-05-2006)
  • HAL Id : inria-00070729 , version 1
Valérie Moreau-Villéger, Hervé Delingette, Maxime Sermesant, Owen Faris, Elliot R. Mcveigh, et al.. Global and local parameter estimation of a model of the electrical activity of the heart. RR-5269, INRIA. 2004, pp.47. ⟨inria-00070729⟩
108 Consultations
132 Téléchargements
