Higher order Moreau's sweeping process: Mathematical formulation and numerical simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
In this paper we present an extension of Moreau's sweeping process for higher order systems. The dynamical framework is carefully introduced, and preliminary well-posedness results are given. The time-discretisation of these nonsmooth systems with a time-stepping algorithm is also presented. This differential inclusion can be seen as a mathematical formulation of complementarity dynamical systems with arbitrary dimension and arbitrary relative degree between the complementary slackness variables. Applications of such high-order sweeping processes can be found in dynamic optimisation under state constraints and electrical circuits with ideal diodes.
RR-5236.pdf (1.21 Mo) Télécharger le fichier
inria-00070762 , version 1 (19-05-2006)
  • HAL Id : inria-00070762 , version 1
Vincent Acary, Bernard Brogliato, Daniel Goeleven. Higher order Moreau's sweeping process: Mathematical formulation and numerical simulation. [Research Report] RR-5236, INRIA. 2004, pp.60. ⟨inria-00070762⟩
160 Consultations
222 Téléchargements
