Over-constrained Weierstrass iteration and the nearest consistent system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Olivier Ruatta
Mark Sciabica
  • Fonction : Auteur
Agnes Szanto
  • Fonction : Auteur
We propose a generalization of the Weierstrass iteration for over-constrained systems of equations and we prove that the proposed method allows us to find the nearest system which has at least $k$ common roots and which is obtained via a perturbation of prescribed structure. In the univariate case we show the connection of ourmethod to the optimization problem formulated by Karmarkar and Lakshmanfor the nearest GCD. In the multivariate case we generalize the expressions of Karmarkar and Lakshman, and give a simple iterative method to compute the optimum. The arithmetic complexity of the iteration is detailed.
RR-5215.pdf (271.49 Ko) Télécharger le fichier
inria-00070779 , version 1 (19-05-2006)
  • HAL Id : inria-00070779 , version 1
Olivier Ruatta, Mark Sciabica, Agnes Szanto. Over-constrained Weierstrass iteration and the nearest consistent system. RR-5215, INRIA. 2004, pp.17. ⟨inria-00070779⟩
78 Consultations
89 Téléchargements
