A Stabilized Finite Element Method for the Oseen Equation with Dominating Reaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Gabriel Raúl Barrenechea
  • Fonction : Auteur
Carolina Ivon Vidal
  • Fonction : Auteur
A new stabilized finite element method is introduced for the linearized version of the Navier-Stokes equation (or Oseen equation), containing a dominating zeroth order term. The method consists in subtracting a mesh dependent term from the formulation without compromising consistency. The design of this mesh dependent term, as well as the stabilization parameter involved, are suggested by bubble condensation. Stability is proved for any combination of velocity and pressure spaces, under the hypotheses of continuity for the pressure space. Optimal order error estimates are derived for the velocity and the pressure, using the standard norms for these unknowns. Numerical experiments confirming these theoretical results are presented.
Autre [cs.OH]
RR-5213.pdf (328.78 Ko) Télécharger le fichier
inria-00070780 , version 1 (19-05-2006)
  • HAL Id : inria-00070780 , version 1
Gabriel Raúl Barrenechea, Miguel Angel Fernández, Carolina Ivon Vidal. A Stabilized Finite Element Method for the Oseen Equation with Dominating Reaction. [Research Report] RR-5213, INRIA. 2004, pp.21. ⟨inria-00070780⟩
187 Consultations
179 Téléchargements
