On stochastic recursive equations and infinite server queues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
The purpose of this paper is to investigate some performance measures of the discrete time G/G/$\infty$ queue under a general arrival process. We assume more precisely that at each time unit a batch with a random size may arrive, where the sequence of batch sizes need not be i.i.d. All we request is that it would be stationary ergodic and that the service duration has a phase type distribution. Our goal is to obtain explicit expressions for the first two moments of number of customers in steady state. We obtain this by computing the first two moments of some generic stochastic recursive equations that our system satisfies. We then show that these class of recursive equations allow to solve not only the G/PH/$\infty$ queue but also a network of such queues. We finally investigate the process of residual activity time in a G/G/$\infty$ queue under general stationary ergodic assumptions, obtain the unique stationary solution and establish coupling convergence to it from any initial state.
RR-5211.pdf (230.38 Ko) Télécharger le fichier
inria-00070782 , version 1 (19-05-2006)
  • HAL Id : inria-00070782 , version 1
Eitan Altman. On stochastic recursive equations and infinite server queues. RR-5211, INRIA. 2004, pp.13. ⟨inria-00070782⟩
75 Consultations
159 Téléchargements
