Optimal concave costs in the SDH context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Jérôme Galtier
  • Fonction : Auteur
Stéphane Pérennes
  • Fonction : Auteur
  • PersonId : 942945
We address a problem of network design with minimum cost, and uniform all-to-all demands between the vertices. We deal with the case of concave increasing link cost function f depending of the capacity over directed arcs. We obtain lower bounds for this problem. In the generic case $f:x\mapsto x^\alpha$, where $\alpha\in[0;1]$, we exhibit some families that constitute an 1.12 asymptotical approximation of the optimal network.
Autre [cs.OH]
RR-5201.pdf (255.56 Ko) Télécharger le fichier
inria-00070791 , version 1 (19-05-2006)
  • HAL Id : inria-00070791 , version 1
Sébastien Choplin, Jérôme Galtier, Stéphane Pérennes. Optimal concave costs in the SDH context. RR-5201, INRIA. 2004, pp.11. ⟨inria-00070791⟩
270 Consultations
115 Téléchargements
