Near-Optimal Parameterization of the Intersection of Quadrics: II. A Classification of Pencils - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
While Part I [2] of this paper was devoted mainly to quadrics intersecting in a smooth quartic, we now focus on singular intersections. To produce optimal or near-optimal parameterizations in all cases, we first determine the the real type of the intersection before computing the actual parameterization. In this second part, we present the first classification of pencils of quadrics based on the type of the real intersection and we show how this classification can be used to compute efficiently the type of the real intersection. The near-optimal parameterization algorithms in all singular cases will be given in Part III [3].
RR-5668.pdf (526.66 Ko) Télécharger le fichier
inria-00071228 , version 1 (23-05-2006)
  • HAL Id : inria-00071228 , version 1
Laurent Dupont, Daniel Lazard, Sylvain Lazard, Sylvain Petitjean. Near-Optimal Parameterization of the Intersection of Quadrics: II. A Classification of Pencils. [Research Report] RR-5668, INRIA. 2005. ⟨inria-00071228⟩
138 Consultations
263 Téléchargements
