Formally certified floating-point filters for homogeneous geometric predicates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2005
Guillaume Melquiond
Sylvain Pion
Floating-point arithmetic provides a fast but inexact way of computing geometric predicates. In order for these predicates to be exact, it is important to rule out all the numerical situations where floating-point computations could lead to wrong results. Taking into account all the potential problems is a tedious work to do by hand. We study in this paper a floating-point implementation of a filter for the orientation-2 predicate, and how a formal and partially automatized verification of this algorithm avoided many pitfalls. The presented method is not limited to this particular predicate, it can easily be used to produce correct semi-static floating-point filters for other geometric predicates.
Autre [cs.OH]
RR-5644.pdf (265.09 Ko) Télécharger le fichier
inria-00071232 , version 1 (23-05-2006)
inria-00071232 , version 2 (04-12-2008)
  • HAL Id : inria-00071232 , version 1
Guillaume Melquiond, Sylvain Pion. Formally certified floating-point filters for homogeneous geometric predicates. RR-5644, 2005. ⟨inria-00071232v1⟩
Collections
INRIA-RRRT
356 Consultations
756 Téléchargements
