s'authentifier
version française rss feed
inria-00071249, version 1
Proposal for a Standardization of Mathematical Function Implementation in Floating-Point Arithmetic
David Defour () 1, Guillaume Hanrot () 2, Vincent Lefèvre 2, Jean-Michel Muller a1, Nathalie Revol b1, Paul Zimmermann 2
N° RR-5406 (2004)
Résumé : Some aspects of what a standard for the implementation of the mathematical functions could be are presented. Firstly, the need for such a standard is motivated. Then the proposed standard is given. The question of roundings constitutes an important part of this paper: three levels are proposed, ranging from a level relatively easy to attain (with fixed maximal relative error) up to the best quality one, with correct rounding on the whole domain of every function. We do not claim that we always suggest the right choices, or that we have thought about all relevant issues. The mere goal of this paper is to raise questions and to launch the discussion towards a standard.
  • Domaine : Informatique/Autre
  • Mots-clés : FLOATING-POINT ARITHMETIC / MATHEMATICAL FUNCTION / STANDARD / IMPLEMENTATION / ROUNDING / EXCEPTION
  • Référence interne : RR-5406
  • inria-00071249, version 1
  • oai:hal.inria.fr:inria-00071249
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 14:52:20
  • Dernière modification le : Lundi 20 Octobre 2008, 15:39:31
tous les articles de la base du CCSd...
