Proposal for a Standardization of Mathematical Function Implementation in Floating-Point Arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Some aspects of what a standard for the implementation of the mathematical functions could be are presented. Firstly, the need for such a standard is motivated. Then the proposed standard is given. The question of roundings constitutes an important part of this paper: three levels are proposed, ranging from a level relatively easy to attain (with fixed maximal relative error) up to the best quality one, with correct rounding on the whole domain of every function. We do not claim that we always suggest the right choices, or that we have thought about all relevant issues. The mere goal of this paper is to raise questions and to launch the discussion towards a standard.
RR-5406.pdf (620.46 Ko) Télécharger le fichier
inria-00071249 , version 1 (23-05-2006)
  • HAL Id : inria-00071249 , version 1
David Defour, Guillaume Hanrot, Vincent Lefèvre, Jean-Michel Muller, Nathalie Revol, et al.. Proposal for a Standardization of Mathematical Function Implementation in Floating-Point Arithmetic. [Research Report] RR-5406, INRIA. 2004. ⟨inria-00071249⟩
237 Consultations
218 Téléchargements
