Towards a Statistical Atlas of Cardiac Fiber Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We propose here a framework to build a statistical atlas of diffusion tensors of canine hearts. The anatomical images of seven hearts are first non-rigidly registered in the same reference frame and their associated diffusion tensors are then transformed with a method that preserves the cardiac laminar sheets. In this referential frame, the mean tensor and its covariance matrix are computed based on the Log-Euclidean framework. With this method, we can produce a smooth mean tensor field that is suited for fiber tracking algorithms or the electromechanical modeling of the heart. In addition, by examining the covariance matrix at each voxel it is possible to assess the variability of the cardiac fiber directions and of the orientations of laminar sheets. The results show a strong coherence of the diffusion tensors and the fiber orientations among a population of seven normal canine hearts.
Autre [cs.OH]
RR-5906.pdf (894.46 Ko) Télécharger le fichier
inria-00071359 , version 1 (23-05-2006)
  • HAL Id : inria-00071359 , version 1
Jean-Marc Peyrat, Maxime Sermesant, Hervé Delingette, Xavier Pennec, Chenyang Xu, et al.. Towards a Statistical Atlas of Cardiac Fiber Architecture. [Research Report] RR-5906, INRIA. 2006. ⟨inria-00071359⟩
100 Consultations
232 Téléchargements
