Fluid-Structure Interaction in Blood Flows on Geometries coming from Medical Imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We address two difficult points in the simulation of blood flows in compliant vessels: the fluid and structure meshes generation and the solution to the fluid-structure problem in large displacements. The proposed strategy allows to perform realistic simulations on geometries coming from medical imaging.
RR-5052.pdf (520.66 Ko) Télécharger le fichier
inria-00071531 , version 1 (23-05-2006)
  • HAL Id : inria-00071531 , version 1
Jean-Frédéric Gerbeau, Marina Vidrascu, Pascal Frey. Fluid-Structure Interaction in Blood Flows on Geometries coming from Medical Imaging. [Research Report] RR-5052, INRIA. 2003. ⟨inria-00071531⟩
159 Consultations
504 Téléchargements
