Estimating seed sensitivity on homogeneous alignments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Laurent Noé
Yann Ponty
We address the problem of measuring the sensitivity of seed-based similarity search algorithms. In contrast to approaches based on Markov models, we study the measurement based on homogeneous alignments. We describe an algorithm for counting and random generation of those alignments and an algorithm for exact computation of the sensitivity for a broad class of seed strategies. We provide experimental results demonstrating a bias introduced by ignoring the homogeneousness condition.
Autre [cs.OH]
RR-5047.pdf (279.47 Ko) Télécharger le fichier
inria-00071536 , version 1 (23-05-2006)
  • HAL Id : inria-00071536 , version 1
Gregory Kucherov, Laurent Noé, Yann Ponty. Estimating seed sensitivity on homogeneous alignments. [Research Report] RR-5047, INRIA. 2003, pp.17. ⟨inria-00071536⟩
105 Consultations
163 Téléchargements
