Stochastic Chemical Kinetics with Energy Parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We introduce new models of energy redistribution in stochastic chemical kinetics with several molecule types and energy parameters. The main results concern the situations when there are product form measures. Using a probabilistic interpretation of the related Boltzmann equation, we find some invariant measures explicitly and prove convergence to them.
Autre [cs.OH]
RR-5008.pdf (280.98 Ko) Télécharger le fichier
inria-00071576 , version 1 (23-05-2006)
  • HAL Id : inria-00071576 , version 1
Guy Fayolle, Vadim A. A. Malyshev, Serguei Pirogov. Stochastic Chemical Kinetics with Energy Parameters. [Research Report] RR-5008, INRIA. 2003. ⟨inria-00071576⟩
65 Consultations
110 Téléchargements
