s'authentifier
version française rss feed
inria-00071613, version 1
Recent Advances in Compression of 3D Meshes
Pierre Alliez () 1, Craig Gotsman
N° RR-4966 (2003)
Résumé : 3D meshes are widely used in graphic and simulation applications for approximating 3D objects. When representing complex shapes in a raw data format, meshes consume a large amount of space. Applications calling for compact storage and fast transmission of 3D meshes have motivated the multitude of algorithms developed to efficiently compress these datasets. In this paper we survey recent developments in compression of 3D surface meshes. We survey the main ideas and intuition behind techniques for single-rate and progressive mesh coding. Where possible, we discuss the theoretical results obtained for asymptotic behavior or optimality of the approach. We also list some open questions and directions of future research.
  • Domaine : Informatique/Autre
  • Mots-clés : GEOMETRY CODING / MESH COMPRESSION / SHAPE COMPRESSION / TRIANGE MESHES / POLYGON MESHES / SURVEY
  • Référence interne : RR-4966
  • inria-00071613, version 1
  • oai:hal.inria.fr:inria-00071613
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 18:16:42
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:25
tous les articles de la base du CCSd...
