Recent Advances in Compression of 3D Meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
Pierre Alliez
Craig Gotsman
  • Fonction : Auteur
3D meshes are widely used in graphic and simulation applications for approximating 3D objects. When representing complex shapes in a raw data format, meshes consume a large amount of space. Applications calling for compact storage and fast transmission of 3D meshes have motivated the multitude of algorithms developed to efficiently compress these datasets. In this paper we survey recent developments in compression of 3D surface meshes. We survey the main ideas and intuition behind techniques for single-rate and progressive mesh coding. Where possible, we discuss the theoretical results obtained for asymptotic behavior or optimality of the approach. We also list some open questions and directions of future research.
Autre [cs.OH]
RR-4966.pdf (1.48 Mo) Télécharger le fichier
inria-00071613 , version 1 (23-05-2006)
  • HAL Id : inria-00071613 , version 1
Pierre Alliez, Craig Gotsman. Recent Advances in Compression of 3D Meshes. RR-4966, INRIA. 2003. ⟨inria-00071613⟩
139 Consultations
853 Téléchargements
