Modeling ADSL Traffic on an IP Backbone Link - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
Measurements from an Internet backbone link carrying TCP traffic towards different ADSL areas are analyzed in this paper. For traffic analysis, we adopt a flow based approach and the popular mice/elephants dichotomy. The originality of the experimental data reported in this paper, when compared with previous measurements from very high speed backbone links, is in that commercial traffic comprises a significant part due to peer-to-peer applications. This kind of traffic exhibits some remarkable properties in terms of mice and elephants, which are described in this paper. It turns out that by adopting a suitable level of aggregation, the bit rate of mice can be described by means of a Gaussian process. The bit rate of elephants is smoother than that of mice and can also be well approximated by a Gaussian process.
Autre [cs.OH]
RR-4909.pdf (775.44 Ko) Télécharger le fichier
inria-00071671 , version 1 (23-05-2006)
  • HAL Id : inria-00071671 , version 1
Nadia Ben Azzouna, Christine Fricker, Fabrice Guillemin. Modeling ADSL Traffic on an IP Backbone Link. [Research Report] RR-4909, INRIA. 2003. ⟨inria-00071671⟩
144 Consultations
170 Téléchargements
