Disjoint Unit Spheres admit at most two Line Transversals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We show that a set of n disjoint unit spheres in admits at most two distinct geometric permutations, or line transversals, if n is large enough. This bound is tight.
Autre [cs.OH]
RR-4854.pdf (228.73 Ko) Télécharger le fichier
inria-00071729 , version 1 (23-05-2006)
  • HAL Id : inria-00071729 , version 1
Otfried Cheong, Xavier Goaoc, Hyeon-Suk Na. Disjoint Unit Spheres admit at most two Line Transversals. [Research Report] RR-4854, INRIA. 2003. ⟨inria-00071729⟩
225 Consultations
99 Téléchargements
