The InfoVis Toolkit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
The InfoVis Toolkit
Jean-Daniel Fekete
This report presents the InfoVis Toolkit, designed to support the creation, extension and integration of advanced 2D Information Visualization components into interactive Java Swing applications. The InfoVis Toolkit provides specific data structures to achieve a fast action/feedback loop required by dynamic queries. It comes with a large set of components such as range sliders and tailored control panels required to control and configure the visualizations. These components are integrated into a coherent framework that simplifies the management of rich data structures and the design and extension of visualizations. Supported data structures currently include tables, trees and graphs. Supported visualizations include scatter plots, time series, Treemaps, node-link diagrams for trees and graphs and adjacency matrix for graphs. All visualizations can use fisheye lenses and dynamic labeling. The InfoVis Toolkit supports hardware acceleration when available through Agile2D, an implementation of the Java Graphics API based on OpenGL, achieving speedups of 10 to 60 times. The report also shows how new visualizations can be added and extended to become components, enriching visualizations as well as general applications.
Autre [cs.OH]
RR-4818.pdf (1.96 Mo) Télécharger le fichier
inria-00071768 , version 1 (23-05-2006)
  • HAL Id : inria-00071768 , version 1
Jean-Daniel Fekete. The InfoVis Toolkit. RR-4818, INRIA. 2003. ⟨inria-00071768⟩
247 Consultations
445 Téléchargements
