An existence result for polynomial solutions of parameter-dependent LMIs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We show in this report that any system of Linear Matrix Inequalities depending continuously upon scalar parameters and solvable for any value of the latter in a fixed compact set, admits a branch of solutions polynomial with respect to the parameters. This result is useful for studying e.g. parametric robustness or gain-scheduling issues.
Autre [cs.OH]
RR-4798.pdf (163.55 Ko) Télécharger le fichier
inria-00071788 , version 1 (23-05-2006)
  • HAL Id : inria-00071788 , version 1
Pierre-Alexandre Bliman. An existence result for polynomial solutions of parameter-dependent LMIs. [Research Report] RR-4798, INRIA. 2003. ⟨inria-00071788⟩
72 Consultations
325 Téléchargements
