Absolute stability and the Lagrange-Dirichlet theorem with monotone multivalued mappings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
This note presents an extension of the absolute stability problem and of the Lagrange-Dirichlet theorem, when the nonlinearities entering the model are considered within the class of monotone multivalued mappings (consequently including operators with piecewise-linear graphs that may represent physical effects like Coulomb friction, dead-zones, saturations, elasto-plasticity, and unilateral constraints).
RR-4794.pdf (305.5 Ko) Télécharger le fichier
inria-00071792 , version 1 (23-05-2006)
  • HAL Id : inria-00071792 , version 1
Bernard Brogliato. Absolute stability and the Lagrange-Dirichlet theorem with monotone multivalued mappings. RR-4794, INRIA. 2003. ⟨inria-00071792⟩
97 Consultations
1340 Téléchargements
