Making a DSM Consistency Protocol Hierarchy-Aware : an Efficient Synchronization Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We consider the design of DSM consistency protocols for hierarchical architect- ures. Such architectures typically consist of a constellation of loosely-inter-connected clusters, each cluster consisting of a set of tightly-interconnected nodes running multithreaded programs. We claim that high performance can only be reached by taking into account this interconnection hierarchy at the very core of the protocol design. Previous work has focused on improving locality in data management by caching remote data within clusters. In contrast, our idea is to improve locality in the synchronization management. We demonstrate the feasibility through an experimental implementat- ion of this idea in a home-based protocol for Release Consistency, and we provide a preliminary evaluation of the expectable performance gain.
RR-4767.pdf (165.91 Ko) Télécharger le fichier
inria-00071819 , version 1 (23-05-2006)
  • HAL Id : inria-00071819 , version 1
Gabriel Antoniu, Luc Bougé, Sébastien Lacour. Making a DSM Consistency Protocol Hierarchy-Aware : an Efficient Synchronization Scheme. [Research Report] RR-4767, INRIA. 2003. ⟨inria-00071819⟩
84 Consultations
295 Téléchargements
