The Middle Product Algorithm, I. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We present new algorithms for the inverse, division, and square root of power series. The key trick is a new algorithm --- MiddleProduct or, for short, MP --- computing the n middle coefficients of a (2n-1)*n full product in the same number of multiplications as a full n*n product. This improves previous work of Brent, Mulders, Karp and Markstein, Burnikel and Ziegler. A forthcoming paper will study the floating-point case.
Autre [cs.OH]
RR-4664.pdf (658.83 Ko) Télécharger le fichier
inria-00071921 , version 1 (23-05-2006)
  • HAL Id : inria-00071921 , version 1
Guillaume Hanrot, Michel Quercia, Paul Zimmermann. The Middle Product Algorithm, I.. [Research Report] RR-4664, INRIA. 2002. ⟨inria-00071921⟩
137 Consultations
1649 Téléchargements
