Minimizing SONET ADMs in unidirectional WDM rings with grooming ratio 3 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Stephan Ceroi
  • Fonction : Auteur
  • PersonId : 1167750
We consider traffic grooming in WDM unidirectional rings with all-to-all uniform unitary traffic. We determine the minimum number of SONET/SDH add-drop multiplexers (ADMs) required when the grooming ratio is 3. In fact, using tools of design theory, we solve the equivalent edge partitioning problem: find a partition of the edges of the complete graph on n vertices (K_n) into subgraphs having at most 3 edges and in which the total number of vertices has to be minimized.
Autre [cs.OH]
RR-4626.pdf (185.3 Ko) Télécharger le fichier
inria-00071959 , version 1 (23-05-2006)
  • HAL Id : inria-00071959 , version 1
Jean-Claude Bermond, Stephan Ceroi. Minimizing SONET ADMs in unidirectional WDM rings with grooming ratio 3. RR-4626, INRIA. 2002. ⟨inria-00071959⟩
139 Consultations
190 Téléchargements
