A Tour of Formal Verification with Coq:Knuth's Algorithm for Prime Numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Laurent Théry
In his book "The Art of Computer Programming", Donald Knuth gives an algorithm to compute the first n prime numbers. Surprisingly, proving the correctness of this simple algorithm from basic principles is far from being obvious and requires a wide range of verification techniques. In this paper, we explain how the verification has been mechanized in the Coq proof system.
Autre [cs.OH]
RR-4600.pdf (185.42 Ko) Télécharger le fichier
inria-00071985 , version 1 (23-05-2006)
  • HAL Id : inria-00071985 , version 1
Laurent Théry. A Tour of Formal Verification with Coq:Knuth's Algorithm for Prime Numbers. RR-4600, INRIA. 2002. ⟨inria-00071985⟩
100 Consultations
1252 Téléchargements
