HArdware Volatile Entropy Gathering and Expansion: generating unpredictable random number at user level - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Nicolas Sendrier
The availability of a random number generator with high cryptographic qualities on a computer is one of the central issues of cryptographic implementations. HAVEGE (HArdware Volatile Entropy Gathering and Expansion) is a new software heuristic for generating unpredictable random numbers on PC s and workstations. PCs and workstations are built around modern superscalar microprocessors. These processors feature complex hardware mechanisms that aim to increase performance. A significant part of the global state of the microprocessor is not architecturally visible through the instruction set (e.g. caches, branch predictors and buffers). HAVEGE leverages the uncertainty introduced in the internal states of the processor by external events. HAVEGE combines entropy/uncertainty gathering from the architecturally invisible states of a modern superscalar microprocessor with pseudo-random number generation. First we show that the hardware clock cycle counter of the processor can be used to gather part of the uncertainty introduced by operating system interruptions in the internal state of the processor. Tens of thousands of unpredictable bits can be gathered per operating system interruption in average. Then, we show how this entropy gathering technique can be combined with pseudo-random number generation in HAVEGE. Since the internal state of HAVEGE includes thousands of internal volatile hardware states, HAVEGE features a very high security level. HAVEGE also reaches an unprecedented throughput for a software unpredictable random number generator: more than 100 Mbits/s with off-the-shelf workstations and PCs.
RR-4592.pdf (305.25 Ko) Télécharger le fichier
inria-00071993 , version 1 (23-05-2006)
  • HAL Id : inria-00071993 , version 1
André Seznec, Nicolas Sendrier. HArdware Volatile Entropy Gathering and Expansion: generating unpredictable random number at user level. [Research Report] RR-4592, INRIA. 2002. ⟨inria-00071993⟩
682 Consultations
408 Téléchargements
