Asymptotic normality of the ET method for extreme quantile estimation. Application to the ET test - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We investigate the asymptotic distribution of the Exponential Tail (ET) estimator of extreme quantiles. We give sufficient conditions for the asymptotic normality and provide some illustrating examples. Then, on the basis of this result, we propose a goodness-of-fit test for the tail of a usual distribution. The asymptotic power and level of the test are established.
RR-4551.pdf (271.03 Ko) Télécharger le fichier
inria-00072037 , version 1 (23-05-2006)
  • HAL Id : inria-00072037 , version 1
Jean Diebolt, Myriam Garrido, Stéphane Girard. Asymptotic normality of the ET method for extreme quantile estimation. Application to the ET test. [Research Report] RR-4551, INRIA. 2002. ⟨inria-00072037⟩
129 Consultations
112 Téléchargements
