Validity Conditions in Agreement Problemsand Time Complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We study the time complexity of different agreement problems in the synchrono- us model with crash failures, by varying their validity condition. We first introduce a continuous class of agreement problems, the k-TAg problems, which includes both the Uniform Consensus and Non-Blocking Atomic Commitment. We then exhibit a general early-deciding algorithm, that we instanciate to solve every problem of this class. The algorithm always achieves the previously established lower-bounds for early-deciding, showing that these lower-bounds are tight.
RR-4526.pdf (229.27 Ko) Télécharger le fichier
inria-00072062 , version 1 (23-05-2006)
  • HAL Id : inria-00072062 , version 1
Bernadette Charron-Bost, Fabrice Le Fessant. Validity Conditions in Agreement Problemsand Time Complexity. [Research Report] RR-4526, INRIA. 2002. ⟨inria-00072062⟩
144 Consultations
142 Téléchargements
