Integrating fast mobility in the OLSR routing protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
Pascale Minet
Khaldoun Al Agha
  • Fonction : Auteur
  • PersonId : 833572
With the current increase in ad-hoc mobile networks in public domains (e.g. airports, parks, stations, etc.), and the widespread use of IEEE802.11 wireless LAN, there is a growing need to handle and manage fast mobility. Extending the coverage area of ad-hoc networks and taking into account fast mobility in routing protocols could offer a complementary solution to the UMTS for the fourth generation (4G) mobile networks. In this paper we present an extension of the Optimized Link State Routing protocol (OLSR), denoted Fast-OLSR. Fast-OLSR is designed to meet the need for fast mobility in Mobile Ad-hoc NETworks (MANETs). Performance evaluation of Fast-OLSR is done by simulation. Simulation results show that the loss rate can be minimized while maintaining a reasonable overhead traffic.
Autre [cs.OH]
RR-4510.pdf (221.39 Ko) Télécharger le fichier
inria-00072078 , version 1 (23-05-2006)
  • HAL Id : inria-00072078 , version 1
Mounir Benzaid, Pascale Minet, Khaldoun Al Agha. Integrating fast mobility in the OLSR routing protocol. [Research Report] RR-4510, INRIA. 2002. ⟨inria-00072078⟩
184 Consultations
557 Téléchargements
