High Throughput Implementations of the RC6 Block Cipher Using Virtex-E and Virtex-II Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
This short paper is devoted to the study of effective hardware architectures for the RC6 block cipher using Virtex-E and Virtex-II FPGA devices. The key point of the implementation is the design of an arithmetic operator computing f(X)=(X(2X+1))2^w. Significant speed and area improvements are obtained by taking full advantage of the small multiplier blocks available in Virtex-II devices.
Autre [cs.OH]
RR-4495.pdf (270.49 Ko) Télécharger le fichier
inria-00072093 , version 1 (23-05-2006)
  • HAL Id : inria-00072093 , version 1
Jean-Luc Beuchat. High Throughput Implementations of the RC6 Block Cipher Using Virtex-E and Virtex-II Devices. RR-4495, INRIA. 2002. ⟨inria-00072093⟩
76 Consultations
224 Téléchargements
