Free Boundary Problemin Norton-Hoff Steady Flow with Thermal Effects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2002
We consider the free boundary identification problem in a steady viscoplastic flow. The fluid motion is governed by the incompressible Norton-Hoff model coupled with the heat equation. The viscosity of the fluid is modeled by the Arrhenius law .Our point of view is to treat the problem as a shape sensitivity of a cost functional formulated on the free boundary and governed by the Norton-Hoff state. One of the main results of this paper is to provide a shape sensitivity result to the considered cost functional.
RR-4417.pdf (331.41 Ko) Télécharger le fichier
inria-00072171 , version 1 (23-05-2006)
  • HAL Id : inria-00072171 , version 1
Jamel Ferchichi, Jean-Paul Zolésio. Free Boundary Problemin Norton-Hoff Steady Flow with Thermal Effects. [Research Report] RR-4417, INRIA. 2002. ⟨inria-00072171⟩
69 Consultations
230 Téléchargements
