Pancyclic arcs and connectivity in tournaments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
A tournament is an orientation of the edges of a complete graph. An arc is pancyclic in a digraph D if it is contained in a cycle of length l, for every $3\leq l\leq |D|$. In [4], Moon showed that every strong tournament contains at least three pancyclics arcs and characterized the tournaments with exactly three pancyclic arcs. All these tournaments are not 2-strong. In this paper, we are interested in the minimum number $p_k(n)$ of pancyclic arcs in a k-strong tournament of order n. We conjecture that (for $k\geq 2$) there exists a constant $\alpha_k>0$ such that $p_k(n)\geq \alpha_kn$. After proving that every 2-strong tournament has a hamiltonian cycle containing at least five pancyclic arcs, we deduce that for $k\geq 2$, $p_k(n)\geq 2k+3$. We then characterize the tournaments having exactly four pancyclic arcs and those having exactly five pancyclic arcs.
Autre [cs.OH]
RR-4378.pdf (245.67 Ko) Télécharger le fichier
inria-00072210 , version 1 (23-05-2006)
  • HAL Id : inria-00072210 , version 1
Frédéric Havet. Pancyclic arcs and connectivity in tournaments. RR-4378, INRIA. 2002. ⟨inria-00072210⟩
200 Consultations
192 Téléchargements
