Fast Redundancy Elimination Using High-Level Structural Information from Esterel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Esterel programs and SyncCharts hierarchical automata are compiled into flat sequential circuits. The current compiling process often generates too many latches and gates. We propose a compositional technique based on structural information that efficiently removes redundant latches and gates, without adding extra logic. The transformation works in linear time and gives good practical results. The simplified circuit can be used for simulation, verification, and optimisation.
RR-4330.pdf (298.49 Ko) Télécharger le fichier
inria-00072257 , version 1 (23-05-2006)
  • HAL Id : inria-00072257 , version 1
Dumitru Potop-Butucaru. Fast Redundancy Elimination Using High-Level Structural Information from Esterel. RR-4330, INRIA. 2001. ⟨inria-00072257⟩
98 Consultations
133 Téléchargements
