Optimal On-Line Estimation of the Size of a Dynamic Multicast Group - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Eitan Altman
  • Fonction : Auteur
  • PersonId : 830042
Philippe Nain
  • Fonction : Auteur
  • PersonId : 833438
In this paper we propose an optimal on-line estimation algorithm for determini- ng the size of a dynamic multicast group. By using diffusion approximation and Kalman filter, we derive an estimator that minimizes the mean square of the estimation error. As opposed to previous studies, where the size of the multicast group is supposed to be fixed throughout the estimation procedure, we consider a dynamic estimation scheme that updates the estimation at every observation step. The robustness of our estimator to violation of the assumptions under which it has been derived is addressed via simulation- s. Further validations of our approach are carried out on real audio traces.
RR-4329.pdf (2.83 Mo) Télécharger le fichier
inria-00072258 , version 1 (23-05-2006)
  • HAL Id : inria-00072258 , version 1
Sara Alouf, Eitan Altman, Philippe Nain. Optimal On-Line Estimation of the Size of a Dynamic Multicast Group. RR-4329, INRIA. 2001. ⟨inria-00072258⟩
Relations
44 Consultations
95 Téléchargements
