Cuts and Flows in Infinite Periodic Graphs; Application to the Minimization of Circuit Registers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Bruno Gaujal
Jean Mairesse
  • Fonction : Auteur
  • PersonId : 831681
In this paper, we prove that bi-infinite and causal periodic graphs admit periodic maximal flows and consecutive minimal cuts. By viewing such a graph as the unfolding of the dependences in a digital circuit, we also show how this can be used for register minimization in circuit design.
Autre [cs.OH]
RR-4144.pdf (367.53 Ko) Télécharger le fichier
inria-00072480 , version 1 (24-05-2006)
inria-00072480 , version 2 (24-07-2007)
  • HAL Id : inria-00072480 , version 1
Bruno Gaujal, Jean Mairesse. Cuts and Flows in Infinite Periodic Graphs; Application to the Minimization of Circuit Registers. [Research Report] RR-4144, 2001. ⟨inria-00072480v1⟩
Collections
INRIA-RRRT
201 Consultations
363 Téléchargements
