Stack Algorithms in Implicit Framing, Free Access and Blocked Access for CATV Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Cédric Adjih
Philippe Jacquet
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
In this paper we present in the framework of access protocols for Cable TV (CATV) networks performant and easy implementation of stack algorithms with an implicit framing scheme. We use a stack algorithm with a single interleaved process in a free or blocked access mode. We show that the blocked access can be implemented to have a deterministic behaviour. We show that a dynamic tuning of the access persistence parameter $R$ improves the performance both in terms of throughput and delays.
RR-4129.pdf (209.57 Ko) Télécharger le fichier
inria-00072499 , version 1 (24-05-2006)
  • HAL Id : inria-00072499 , version 1
Cédric Adjih, Philippe Jacquet, Paul Mühlethaler. Stack Algorithms in Implicit Framing, Free Access and Blocked Access for CATV Networks. [Research Report] RR-4129, INRIA. 2001. ⟨inria-00072499⟩
77 Consultations
58 Téléchargements
