A Variational Approach to Multi-Modal Image Matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Christophe Chefd'Hotel
  • Fonction : Auteur
Olivier Faugeras
We address the problem of non-parametric multi-modal image matching. We propose a generic framework which relies on a global variational formulation and show its versatility through three different multi-modal registration methods : supervised registration by joint intensity learning, maximization of the mutual information and maximization of the correlation ratio. Regulariz- ation is performed by using a functional borrowed from linear elasticity theory. We also consider a geometry-driven regularization method. Experiments on synthetic images and preliminary results on the realignment of MRI datasets are presented.
RR-4117.pdf (752.05 Ko) Télécharger le fichier
inria-00072513 , version 1 (24-05-2006)
  • HAL Id : inria-00072513 , version 1
Gerardo Hermosillo, Christophe Chefd'Hotel, Olivier Faugeras. A Variational Approach to Multi-Modal Image Matching. RR-4117, INRIA. 2001. ⟨inria-00072513⟩
187 Consultations
1166 Téléchargements
