A BFGS-IP algorithm for solving strongly convex optimization problems with feasibility enforced by an exact penalty approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Programming Année : 2002
Paul Armand
Sophie Jan
This paper introduces and analyses a new algorithm for minimizing a convex function subject to a finite number of convex inequality constraints. It is assumed that the Lagrangian of the problem is strongly convex. The algorithm combines interior point methods for dealing with the inequality constraints and quasi-Newton techniques for accelerating the convergence. Feasibility of the iterates is progressively enforced thanks to shift variables and an exact penalty approach. Global and $q$-superlinear convergenc- e is obtained for a fixed penalty parameter; global convergence to the analytic center of the optimal set is ensured when the barrier parameter tends to zero, provided strict complementarity holds.
RR-4087.pdf (415.75 Ko) Télécharger le fichier
inria-00072546 , version 1 (24-05-2006)
Paternité - Pas de modifications
Paul Armand, Jean Charles Gilbert, Sophie Jan. A BFGS-IP algorithm for solving strongly convex optimization problems with feasibility enforced by an exact penalty approach. Mathematical Programming, 2002, 92 (3), pp.393-424. ⟨10.1007/s101070100283⟩. ⟨inria-00072546⟩
135 Consultations
217 Téléchargements
