A Two-Level Checkpoint Algorithm in a Highly-Available Parallel Single Level Store System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
A Parallel Single Level Store systems (PSLS) integrates a shared virtual memory and a parallel file system. Managing globally the data, they provide programmers of scientific applications with the attractive shared memory programming model combined with a large and efficient file system in a cluster. In this paper, we present a cheap and efficient two-level checkpointi- ng approach enabling a PSLS to tolerate failures. The first level checkpointing algorithm is very efficient and saves data in memory but requires a large amount of memory space. When memories are saturated, an alternative algorithm, saving a checkpoint on disks is implemented. Performance results present the impact of different variants of the checkpointing algorithms.
RR-4086.pdf (124.82 Ko) Télécharger le fichier
inria-00072547 , version 1 (24-05-2006)
  • HAL Id : inria-00072547 , version 1
Christine Morin, Renaud Lottiaux, Anne-Marie Kermarrec. A Two-Level Checkpoint Algorithm in a Highly-Available Parallel Single Level Store System. [Research Report] RR-4086, INRIA. 2000. ⟨inria-00072547⟩
142 Consultations
216 Téléchargements
