Coupling Dense and Landmark-Based Approaches for Non Rigid Registration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Pierre Hellier
  • Fonction : Auteur
  • PersonId : 830127
Christian Barillot
In this paper, we investigate the introduction of cortical constraints for non rigid inter-subject brain registration. We extract sulcal patterns with the active ribbon method, presented in [24]. An energy based registration method [21] makes it possible to incorporate the matching of cortical sulci, and express in a unified framework the local sparse similarity and the global ``iconic'' similarity. We show the objective benefits of cortical constraints on a database of 18 subjects, with global and local measures of the registration's quality.
RR-4076.pdf (512.72 Ko) Télécharger le fichier
inria-00072557 , version 1 (24-05-2006)
  • HAL Id : inria-00072557 , version 1
Pierre Hellier, Christian Barillot. Coupling Dense and Landmark-Based Approaches for Non Rigid Registration. [Research Report] RR-4076, INRIA. 2000. ⟨inria-00072557⟩
89 Consultations
332 Téléchargements
